Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Does the SW have a fan for the radiator or does it simply rely on air flow and front/rear heat exchangers? Was running a long trail with lower but hard packed snow conditions and it was shutting down because it was overheating. While waiting for it to cool down, never heard a fan come on. Once in deeper snow, was normal. Seems to run hotter than the Viper did.
Silkysmooth3popper
- Mar 19, 2013
There is no front radiator like the Viper has. The turbo intercooler is in that spot. All you have is heat exchangers in the tunnel and in front of the track.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
I would invest in some ice scratchers.
Sent from my iPhone using Tapatalk Pro
Apex2006
- Oct 26, 2009
- McHenry, IL
Thank you!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Should be running around 172. That's were most are when cooling good and trail running.. I always have the temp display up on the dash. And the Viper usually around 167 if I remember
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
only went for one ride so far...but is there are way to display coolant temp in degree's and not just the bar across ? Mine seemed to stay a little over halfway to the H
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Press and hold the lower left hand button until the numbers show up
silverram323
- Mar 24, 2013
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Just wondering, with these gauges doing alot, do they have a MPG mode too? I know im a dork but i like that on the doo.
thnx
Dan
thnx
Dan
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
thnx
Dan
Not that Ive found, would be kinda neat. Is it accurate on your Doo?
- 29K
