msgt van
Is the black cap that's on the front of the suspension rail supposed to be loose/flop around? It is held on by rivet, but it seems strange that it's able to move around.
RAMSOMAIR
Yep, just rattles around
msgt van
Just seems wrong!!
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
when I had my rails powdercoated, I put larger diameter rivets in, and it took the slop away. It was really a non issue to it's performance.
There is a write up on this issue in the TY Tech or FAQ's.
I removed my caps and filled them with windshield urethane and installed new rivets with washers. No more rattle.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
When new they are snug. Over time they loosen up. Also have seen quite a few rails with wear from the cap rattling around. The rivet holes loosen up so i often grind some flat spots on oversized washers to fit them in pocket and re-rivet.
msgt van
Thanks for the info!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
had a bud lose one and stab his track. track came out at 80 on a lake no brakes good thing it was open space in front of him just coasted to a stop. after that I drilled them out on all our sleds and through bolted with ny-loc nuts. no more issue after that.
theCATman
Anytime any have loosened up, I take them off, lay a good thick bead of ultra black silicone on the rail end, and bolt them back on with a nyloc.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
put a 5mm bolt in with washer and you are good to go.
