rkkoeb
I removed my rear suspension out of my 09 apex to rebuild the shock and powder coat the parts. I notice the end caps on the rails are pretty warn out. Does anyone have a good place to purchase these from?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Barn of Parts, has lots of used parts for YAMAHAs if you give Travis a call he will send you what you need.
IH8CROWS
Use a larger fastener than the original rivet and I put a bunch of good quality silicone in them before install to keep them from vibrating.
yamadoo
- Jun 3, 2003
Like 74Nitro stated when I replaced mine I siliconed them and used a stainless steel bolts and locking fastener, never loose again. Sold in about 4K miles after redo.
rkkoeb
I will reach out to Travis and see if he has a new set
rkkoeb
I also need a set of rear suspension bushings being that I have it all apart
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
henseljg2 get in touch with him he has the best used Apex parts.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
$25 each from Port Yamaha, recommend them if wanting new, site sponsor! Give Kevin a call!I removed my rear suspension out of my 09 apex to rebuild the shock and powder coat the parts. I notice the end caps on the rails are pretty warn out. Does anyone have a good place to purchase these from?
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Yes they are a little cheaper there, however Port is a site sponsor so please use them for new parts.
rkkoeb
Do you have Kevin's E-mail address as I have a few things that I need
RobX-1
- Coldwater, OH
You can PM using his TY handle @Port-Parts
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I order my parts online, if I have any questions or concerns I call him.Do you have Kevin's E-mail address as I have a few things that I need
https://shop.portyamaha.com/fiche_select.asp
