pup55
Going over bumps at slow speed I get a ratchet noise coming from underneath my sled and it sounds like it is the track and the drive sprocket. Could it be track to loose, limit strap?
apex4
Are you sure it is not your transfer rod?
pup55
are you talking rear transfer rods? It really sounds like it is up front and only when i go over bumps slow. At higher speeds i do not here it.
blackattak
Monoshock suspension sounds clunky at low speeds. Track ratchet would be when you jump on the throttle on the trail, or might ratchet in deeper powder when you hit the throttle.
I suspect it's the transfer rod. You get use to it, but each season when I hear the clunking I figure something is broken- but nver has been for me.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
blackattak said:Monoshock suspension sounds clunky at low speeds. Track ratchet would be when you jump on the throttle on the trail, or might ratchet in deeper powder when you hit the throttle.
X2
pup55
So nothing to worry about.
redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
Nope, nothing to worry about. Mine has been clunking at low speeds on bumps since day one. I do the same thing as Black Attak, though, and think that something is wrong.
