hi allen.
i will be shooting you a pm to make shure of this but since i could not find a record of the bearing # for these wheels, i thought i would post it up here as well.
i know the standard 5" wheels take 2 6905rs bearings per wheel as i just took mine apart for bearings (3 years).
i need to know what the rear wheels take (7") as i am going to pull the axle and do them while i am at it.
thanks maim.
thanks maim.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
5.35" wheels = 6905 bearing
7" & 7.25" wheels = 6004 bearing
thanks allen.
Grimm
Srxspec said:5.35" wheels = 6905 bearing
Never heard of a 6905 bearing...could this be a typo? Googled it just now and the 6905 bearing is only 9mm wide.
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
6905 is the correct bearing,each wheel uses 2 bearings.I hadto replace all mine after one season-2000 miles
yep. there is 2 in each idler. wheels do not wobble as much with this set-up.
