Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I am having similar issues on my 17 LTX-LE .So I rode 250km today, I even put my torsion springs back on 2 and it rode amazing. Half the time I stopped it was "sagged down" a bunch and the other half it was fine. And it was pretty much all flat terrain, so weird.
Sag and bottoming .
Had my shocks done end of ly , so I figured its my torsions , as I constantly carry heavy tunnel bag , and big Linq gas can .
Ordered the 5 position cam from Star .
Will see how that helps.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
It was super busy last week (Wed-Fri) but on Friday the trails were ROUGH (60km from Smooth Rock to Cochrane basically 2ft moguls the whole way but it's a combination of lots of traffic, warm weather, sugary snow and no time to groom everything every single minute but the groomers did a great job and caught up) but after Friday I think a bunch of people went home. Could also be because we moved from Cochrane to Timmins and started there cuz surprisingly Sat/Sunday was very quiet and the trails were really good.I bet Cochrane was crazy this weekend eh!!
Trail around here(Sudbury area) should be opening this week with all the snow in forcast
JayM
- Oct 29, 2018
- Pickering, ON
Ok, had some time tonight to pull the skid finally, shocks seem to work as they should, I re-greassed and put it back together. When I measure the sag I'm right at 3" which is my target and when I lift the rear and lower down the track hits the floor flat which is also what I'm aiming for.
There's just this area at the top of the travel that seems weird, maybe I just never noticed this before? Here's a video.
Is that simply the front arm of the rear suspension moving in the "slot"?
JayM
- Oct 29, 2018
- Pickering, ON
Good question, I haven't looked at that and you might be right? Seemingly everything looks good. This is what happens when there's no snow, too much time in the garage lol
Turboflash
- Mar 18, 2019
- Southern MN
LOL! I can relate. Waiting for snow, I'd go over and over and over my sled hoping I could find something to work on. The corollary to "don't fix it if it ain't broke" is "fix it til it is broke." LOLGood question, I haven't looked at that and you might be right? Seemingly everything looks good. This is what happens when there's no snow, too much time in the garage lol
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I just put the 5 sided Star cam on at the 4th setting , which is more than stock , and it still has as much or more travel than you have that doesn't return , even though it appears the sit on sag is 3inches .Ok, had some time tonight to pull the skid finally, shocks seem to work as they should, I re-greassed and put it back together. When I measure the sag I'm right at 3" which is my target and when I lift the rear and lower down the track hits the floor flat which is also what I'm aiming for.
I also regreased the shafts , and no diff.
This is a pic of the new cam on the softest setting.
JayM
- Oct 29, 2018
- Pickering, ON
This is a pic of the new cam on the softest setting.View attachment 152182
I have thr Yamaha 4 sided block and same difference, it's got to be the "slide action" that's doing that as the front arm slides on thr shaft as suggested which should be "normal".
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
You don't have your skis up on dollies do you? That causes the back to collapse.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Any chance the shocks were revalved?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Normal, same on all sleds.
JayM
- Oct 29, 2018
- Pickering, ON
Nope, on the ground.You don't have your skis up on dollies do you? That causes the back to collapse.
I had the rear shock revalved yes.Any chance the shocks were revalved?
Yeah I'm leaning there, thanks!Normal, same on all sleds.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
It’s called shock fade. Synthetic oil helps but it’s normal.
Sounds like standard fox oil was used to rebuild them, next time use AMS shock oil.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
The new sleds in the showroom don't appear to sag .It’s called shock fade. Synthetic oil helps but it’s normal.
So I thought it might be a temp related issue , but mine still sags no matter indoors /outdoors on cement floor or snow , greased or no grease .
Even right after the shocks being serviced , and ridden once , it has that sag.
So maybe there is an inherant sag in the torsions onced used , no matter what setting the cam is at ?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well it can also depend on how much nitrogen charge the shock rebuilder used.
