snoman
i looked all over for a rear radiator all over i know i seen one some where and i cant find it.can some one help me find the rear radiator for apex.and also when i turn my ride on the warm up light does not turn on.i'm a newbie on 4 stroker i just upgrade from dog team jk lol.any who i love the apex and after i break it in you'll feel the world spin the other ways when i wot hehe.
sniperviper
Is it recomended to add a rear heat exhanger on this sled?
I know there was some problems with rx1's according this issue but I havent heard about cooling problems on the apex...?
Would be nice to know beacuse I'm just to start this season with my 06 rtx and I have a rear heat echanger laying somewere from a srx 700 and I guess this will fit right on the apex...?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
sniperviper said:Is it recomended to add a rear heat exhanger on this sled?
No issues with that machine. I had the same sled. As long as the antifreeze is a normal mix, you should be fine. Both my 06 RTX and 2007 Attak came from the factory 100% antifreeze.
jlemieu1
- Feb 7, 2005
- Rosemount, MN
- 14 Viper LTX SE, 14 Viper LTX
Sorry, I have a stupid question. How can you tell if you have 100% antifreeze in your machine?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
jlemieu1 said:Sorry, I have a stupid question. How can you tell if you have 100% antifreeze in your machine?
Go to your local auto store and pick up a hydrometer. That's a fancy name for a tool that measures the specific gravity of a liquid. It is indexed to give you a reading of what temp your coolant is safe to.
theflamanguy
OK, so what temp is 100% antifreeze safe to?
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
theflamanguy said:OK, so what temp is 100% antifreeze safe to?
You don't want 100% antifreeze. 50/50 or 60/40. He was saying 100% antifreeze was the problem. If your sled doesn't overheat, dont worry about it. If it does, check it. You can buy a cheap one at an auto part store for $3 - $10.
4500 miles on my sled and never overheated except on the asphalt
jlemieu1
- Feb 7, 2005
- Rosemount, MN
Here is my (rookie) idea how to check your coolant. First of all you need to find a Ethylene Glycol coolant checker NOT a Propylene Glycol. I ran into this before when I worked on Propylene Glycol HVAC system. Here is a model I found that can tell you if your coolant is over a 70/30 ratio.
Cooling System Diagnostics, Anti-Freeze Tester for Ethylene Glycol (Thexton: model 106)
- 11K
