oldyami
- Jan 25, 2010
Does anyone know where to find the 2010 set up spec charts?I'm trying to set the sag on my 2010 vector ltx.Clip is in #3 position and the sag is 10mm.Yamaha says to set at 40 -45 mm.According to my calculations I would have to move the clip to the #1 or standard position for my weight.Has anyone else tried these adjustments?
studdog
I don't know whether #3 position is hardest or sodtest. I suspect it's hardest. Mine cam set in softest #1. This suspension is quite firm compared to prior years. I weigh 190 lbs. I have my rear set full soft. And it still is a little on the firm side for my liking. Only solution is weaker spring. All in all great sled and good ride. Hope this helps.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Although I think this is for older sleds than yours you may find some good info in it?
Good Luck
http://www.totallyamaha.com/snowmobiles ... Index.html
Good Luck
swmichvector
if you are mot happy with the ride send your shocks to pioneer and have them re valved. i am going to get mine to them before it gets cold.
