pudge
are the shafts used in the rear suspension of a 2006 nytro mild steel or high grade steel? the main shaft that connects the center and rear shock together was bent towards the rear of the sled. the pivot system for the two shocks was crooked also. i straightened out the bracket and will have to beef it up some how.
is there any companies that make a stronger shaft? a new one cost $25 but that will bend also. gonna to beef up the rear suspension with chrome-moly tubing has anybody else done this?should i just use 2007 parts?
