Relocation of Vent Filter
  • Thread starter Thread starter Anonymous
  • Start date Start date
hey Rob,
i drilled out the factory fill pulg and fitted it with a 3/8 pipe that is epoxied in place and has a transition to 5/8 OD. then i sliped the heavy duty heater hose over it. the existing crankcase vent is the 5/8 hose starting at catch can and running under fuel pumps, along engine and 90 degree elbow to pop up right in front of gas tank. i made steal wire brackets (like coat hanger wire) and covered with black rubber vacume hose, that are attached to the gas tank float plate, i replaced the stock screws with longer alen head bolts and wraped the steel wire around them. this spot under the hood is ideal there is no clearance problems.
i must tell you i have 0 miles on this set -up, although i have run the motor alot and see no oil. i also belive many other T Y members are using a similar set up with out any trouble. hope this helps, feel free to pm me and i will supply more pictures and info if you want.
rfc
skip
All I did with the oil plug was replace it with a PVC plug and grommet, fits in there nice and tight, then ran the hose up to the one coming off the catch can and tee'ed it in, this way you only have to have 1 filter.
