Mcmarkrazz
- Dec 28, 2013
Got a 2013nytro the other day and need to get the bars forward for a better ride asap.
Need some feedback on which relocator kit to go with.is the forward movement the same with all or does one make offer more forward positioning.
Also input on how hard they were to install.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Oft racing difficulty 2/10
Quality product!!
Quality product!!
Yama 1000
I have the oft and have had it on my sled for two years and love it. Great product, great quality.
herndonp
x2 on the OFT would never go back.
Pete
Pete
RobWarrior
You won't find anyone say anything bad about the OFT...I went with the BDX and love it...a little more cash but I found one in August for $226 and free shipping. Don't think you can go wrong with either but the BDX will be more vertical.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
OFT
dubweiser
in theory couldn't the same thing be accomplished by adding a 2" pivot riser ?
I plan on doing the oft, but just thinking the pivot would essentially be the same
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
sheetwright
I have used oft on my last one. Great product, great owner etc. just a tad pricy, and deliveries depend on availability of stock. This Time I went with PMT's model. Good quality, cheaper, and does the job. The main difference is instead do a bushing sleeve there is a grease relief machined into the brackets. Which you can pack with low temp grease then clamp together. Here are some pics. You can see them in ebay FYI
RobWarrior
dubweiser said:in theory couldn't the same thing be accomplished by adding a 2" pivot riser ?
No the pivot riser won't change the arc the bars rotate in. All the relocaters work just to a different degree...OFT and PMT about the same...I think its a 6 degree move forward, Grizz's might be a little less and the BDX with the U-joint moves the arc the most vertical...not sure of the actual degree. You can ride all day and not feel any fatigue. It is kind of odd the steering still feels heavier than many other sleds but the position is so good you have better leverage.
Hannibal802
Old thread, but looking for the same options in 2020. Most sites are dead, where can you get a steering relocate kit these days?
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I think Cr racing still sells them or build one yourself like grizz did. It’s very simple to build.
RobX-1
- Coldwater, OH
@hibshman25 (Travis) at Barn Of Parts sells a kit for $40
https://www.barnofparts.com/apps/webstore/products/show/7228578?siteId=134334799&locale=en-US
Hannibal802
Yeah I saw that, I was trying to get an idea what other kits looked like. I saw photos that some are a whole streering assembly and some are just a bracket. I'm not really setup to make the 1.75" diameter bend.
zx4ever
- Apr 14, 2011
The bend is not needed just 2 plates.Yeah I saw that, I was trying to get an idea what other kits looked like. I saw photos that some are a whole streering assembly and some are just a bracket. I'm not really setup to make the 1.75" diameter bend.
