removal of chaincase
Best description I got was from TurboJaime and its to basically keep the shift forks straight up at 90 degrees from the face of the cover as you slide the chain case on and peering through the top little crack as you near the reverse gear slowly let the shift forks down into the slot as your pushing it on the shaft all in one motion. Its really tricky the first time then its like riding a bike. Good luck!
I have the procedure covered in both pics and words in my "rxrider's turbo garage" thread, can't remember which page it's on, have to make an index on of these days.
Thank you both Kinger & rxrider. Now it makes sense!
Will try this at lunch.
Yummy.
