hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Installing a Hurricane header and was wondering if there was anything to know about removing the gas tank?
Did you do a search on this? We just talked about this in the Viper section. Dont break the clip on the fuel line.. LOL Everything else is a walk in the park.
hman4
- Sep 22, 2014
Thanks, I will check that out.
blue fun
- Sep 22, 2007
- Mn
- 2017 sidewinder,2006 apex gt,several srx,s
- Mn
Installed mine today... It's not to bad but I did find it easier to undo the rest of the steering post to make it easier to install the new uprite ...then you don't have to remove the cast bracket that the turbo mounts to..
hman4
- Sep 22, 2014
I got the stock manifold off but didn’t get the new one on yet. I had to have a cut off Torx bit to get the exhaust off that I figured I would take care of at work tomorrow. Had a little trouble getting one of the stock manifold bolts off but came up with something that worked.
blue fun
- Sep 22, 2007
- Mn
- Mn
When you get the new one from Dave it comes with a new aluminum piece that is bent In way to clear the new header. You will see what I'm talking about then. It's not to bad to installI got the stock manifold off but didn’t get the new one on yet. I had to have a cut off Torx bit to get the exhaust off that I figured I would take care of at work tomorrow. Had a little trouble getting one of the stock manifold bolts off but came up with something that worked.
hman4
- Sep 22, 2014
I have the new header but needed to remove my exhaust so I could change out that support. How did yours turn out. The header is a nice looking piece.
blue fun
- Sep 22, 2007
- Mn
- Mn
Mine turned out nice. I must have missed something on the heat shield templet because I marked as it shows to and it was off bit. Not a big deal just trimmed some more off and was good to go.I have the new header but needed to remove my exhaust so I could change out that support. How did yours turn out. The header is a nice looking piece.
hman4
- Sep 22, 2014
Having a little more to trim off is a good thing!
blue fun
- Sep 22, 2007
- Mn
- Mn
Very true!!!!!!Having a little more to trim off is a good thing!
hman4
- Sep 22, 2014
Thanks Blue fun for the hint on removing the
Steering post to remove and install the new suport. Way easier!
blue fun
- Sep 22, 2007
- Mn
- Mn
no problem !!! What else are you doing? I've done the hole nine yards on mine.Thanks Blue fun for the hint on removing the
blue fun
- Sep 22, 2007
- Mn
- Mn
no problem !!! What else are you doing? I've done the hole nine yards to mine.
hman4
- Sep 22, 2014
My sed is an RTX LE, so I have basically copied all of rockerdans mods and for the motor mods I have the Hurricane header, flasher, tunes, AFR module and clutching. I made up my own CAI. I’m going to use a Turbo Dynamics Turbo force can.I’m just finishing studding it and should be receiving the last of my parts shortly, at least for this season.
