Removing Oil Pan
Steve_Vo
Age
48
Paradise, Newfoundland
Canada
2009 Nytro XTX
Hey! I’m new to this forum, but have had a Nytro for 7 years now. My 2009 XTX oil pan has a pinhole leak (I guess I landed hard a while ago, and bent the metal support on the belly pan, which rubbed through the pan). Does anybody know if the subframe has to be removed to take the oil pan off?
I wouldn’t attempt it with the subframe attached. Pulling it off isn’t all that tough, do a search and follow one of the great re and re write ups on the forum.
Time for a Mountaintech skid plate! Another OEM "engine protector" failure.
Contact Peter at Mountaintech and install his skid plate to protect the engine and heat exchanger. It has saved my "bottom end" a few times.
