Removing Subframe
wshellrider
Wpg, Mb
Hey guys, I would like to pull off my subframe this weekend to install the Grizz Gusset. Are there any instructions on how to do this or it it easy enough to find all the bolts that hold it on? I assume after I pull off the plastics and and suspension the subframe will be accessable? Any advice would be great. Thanks.
I did mine a week or two ago, you dont even need to remove the a arms or shocks. About 6 or 8 bolts on each side to hold it once the plastic is off. Dont forget to hold up the motor and chasis though.
oh nvm I get it. The engine and chassis will still be tied together, just have to support it under the running boards or whatever. Gotcha!
i did it in a parking lot this winter with a tree stump under the engine, had her swapped in about 3 hrs with hand tools...
Is it safe to leave it supported on the engine? The sled is at the lake, I want to bring the frame home for the week to weld.
I wouldn't support it by the oil pan. Here is the basic procedure for removal: Subframe removal
