Has someone change grips on a Sidewinder? I just bought an MTX and one of the hand grips is damaged on the outer end. So I need to replace it, but i don't know how to do it.
X2
If that doesn't work use a razor blade and LIGHTLY score the grip being careful not to go through. Then just rip it. Only glue is right by the blocks but these new grips are a very tight fit so air may not be enough. Put new one on using Hairspray.
