Replacement bolts for the lower "fixed" side panel
xcsp
Wisconsin
Has anyone found a suitable replacement bolt, preferably with a "allen" head to replace the Philips-head screws that secure the black plastic panels below the removable side panels?
Possibilities
I did a search and came up with this thread:
http://www.ty4stroke.com/viewtopic.php?t=30213&highlight=screw+panel
At the end of page 2 are a few possibilities, one being some stainless hardware, and the other is that a fastener now used on the new Phazer shrouding/body panels, could possibly work.
The part # for the bolts on the Phazer, from what I seen on Yamaha's parts-look-up page is 90109-06220-00. (.60 each)
There is another one used on the Phazer panels that I'll check out as well, part# 5PW-28386-00-00. (Not sure if this is right, but shows on a dealer site that the cost of this is over $5!, maybe an error on the part #?)
Not sure which of these two bolts listed above is what was referred to in the referenced posting.
The part# for the bolts on the Apex/Attak/RX1 is 90154-06009-00. (.98ea.)
I plan to see if a local shop has all three fasteners in stock to compare them.
Re: Possibilities
let me know how you make out, thanks
I just got a handful of stainless allen head machine screws from work. They work GREAT. Problem is I cant remember the size. I'll find out sunday night and post it monday morning.
screws
Well, the dealer didn't have either screws in stock, but they are both 6mm, not sure on the length.
The Phazer uses a hex-head style fastener which would be nice, rather than that Philips=-head on the Apex.
GUYS......just buy yourself a #3 philips SOCKET,which will go into a 3/8 drive ratchet....with the #3 socket you will never strip one of those little screws anymore..
I assume this is why you want to change them?..
Dan
