Replacing 06 Nytro Handlebars
bambam0325
Macomb,Mi
I have to replace the handlebars on my 06 Nytro because they are bent. I have hooked bars currently. If I replace just the bars and used the hooked from the current set what else do I have to do? If I remove the grips on the hooked current set is the heating element glued down? How can I get that off to reuse? I beleive if I get the grip off there is a bolt that is driven into the bars, is that true? Also there is a rivet, does this hold the grip on? Any help I could get to just replace the bar and utilize the other parts from the old assy would be helpful.
Replacement Bars
If Im reading correctly there is a replacement set for 06 Nytros, where they have hooked bars and elements as I piece. Does anyone have a part number for this kit?
I was told that the replacement program was done.........I had mine reserved from last season and just had them changed a couple of weeks ago......
