brmurph
- Apr 28, 2013
- Austin, TX .
- 2012 APEX XTX
- Lake Vermilion MN
Anyone know the procedure to replace coolant on 2012 APEX XTX? Looking for drain plug, bleeders and best practices to bleed it.
Thanks.
Thanks.
we did mine 2 years ago when i installed a coolant heater. drained it from the hose that i put the heater in by the chaincase. we burped mine through the rad cap by putting the front skis up on a pair of milk crates and running it up to tempurature twice like that. checked on it after and only had to add to the overflow bottle to top off the system.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Did the same thing to my short track apex. A tip, While in that position fill VERY slowly as this helps the air work its way out without creating air pockets. Still warm up to temp and purge but this helps a lot!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
on the tunnel over the rear heat exchanger in a plastic plug remove that and the bleeder is right there. drain by removing the hose that runs under the chain case to the front RAD as described above.
brmurph
- Apr 28, 2013
- Austin, TX .
- 2012 APEX XTX
- Lake Vermilion MN
Thanks all!
