mattison
- Mar 12, 2019
- RI
- 2010 RS Vector, 2011 Apex SE, 2016 Apex LE
2016 Apex LE, I want to change out one of the graphic stickers that suffered from a cover rubbing on it. Does anyone have any tricks to install new sticker without getting bubbles from the slight curve of the panel (side panel)?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Get the old decal off and all of the adhesive. A Little heat from a hair dryer helps loosen the old adhesive. If this is on a smooth or painted panel this has worked for me. Once it’s clean mix up a little soap and water in a spray bottle and wet down the panel. Peel off the backing and place the new decal on the panel. You can easily reposition it with the soapy water under it. When you have it where you want it start in the middle and squeegee towards the edges. Lightly blot it dry with a towel and let it sit. It will dry out after a day or so and be good to go.
mattison
- Mar 12, 2019
- RI
Thanks. Wasn't sure the soapy water trick would work on these stickers. There's a clear plastic layer on the face of the sticker, does this need to come off first?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
I usually take off any protective film after the decal has been applied.
That extra layer is called "premask". This helps keep the graphic together and aids in installing the graphic without stretching it. If using soapy water to install the graphic wait a day for the water to dry out and the adhesive to stick to the plasticThanks. Wasn't sure the soapy water trick would work on these stickers. There's a clear plastic layer on the face of the sticker, does this need to come off first?
mattison
- Mar 12, 2019
- RI
With the curve of the panel, it seems like the graphic would have to stretch a bit to conform.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
I used a heat gun to help with the curves and I also used Windex instead of soap and water
