Fermium1
Working on a rx1 warrior. Head was machined to correct warp. Is the factory headgasket sufficient, do I need to stack gaskets or is there a special thicker gasket that's normally used? Also, do I need to replace the head studs on this as well? I apologize if these questions have already been answered previously, I searched the forum and didn't see an answer.
it should be fine with the stock gasket. i am paranoid and would coat both sides with avation form a gasket or a light film of grease to ensure a good seal. if no turbo, should be fine with stock studs if they are not torque to yeild type.
Fermium1
Yes, no turbo, stock machine. Thank you!
