Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
After 14,000 miles my stator looks like an overcooked hamburger. So I'm replacing it. When I took the cover off, one of the gears and shaft fell out. Anyone have a picture or diagram how all of that goes together in there. I can't find anything helpful on a parts diagram. Trying to get it right so I don't do any serious damage.
Thanks for the help.
I have a thread where I put Sidewinder stator in my Viper. Should be lot of pics. Will look for it.After 14,000 miles my stator looks like an overcooked hamburger. So I'm replacing it. When I took the cover off, one of the gears and shaft fell out. Anyone have a picture or diagram how all of that goes together in there. I can't find anything helpful on a parts diagram. Trying to get it right so I don't do any serious damage.
Here
Sidewinder Stator,Pickup Coil,Flywheel and Cover on Viper
The goal of this conversion is twofold. #1 Increase Top End Performance #2 Eliminate a Variable that MIGHT cause erratic idle and other engine running qualities I have never understood why the ignition pickup on the Nytro and Vipers was placed on the Stubshaft our Primary clutch is attached...
ty4stroke.com
Phazer2Viper
- Apr 14, 2014
exactly what i needed. Thanks!
Phazer2Viper
- Apr 14, 2014
Hey Cannon. I'm putting everything back together and im having problems keeping the gasket centered. how did you do that?Here
The goal of this conversion is twofold. #1 Increase Top End Performance #2 Eliminate a Variable that MIGHT cause erratic idle and other engine running qualities I have never understood why the ignition pickup on the Nytro and Vipers was placed on the Stubshaft our Primary clutch is attached...ty4stroke.com
Pretty sure there is dowel pins. Put those in block.Some rtv by the grommet. Should stay.
used grease to hold it a few times when i did not have hitac to spray on one side of housing.
