race24x
So I am servicing my primary with all of the failures I have read about a little locktight and checking the bolts for a long trip. Primary spring is stock and has some miles and years on it. I ordered a Dalton black blue bit it is considerably shorter. The wire diameter is larger but I want to make sure this is right before putting it in.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Stock spring is a long one. I just put a Yamaha Blue Brown Blue primary on and it was much shorter also.
Stock one is at bottom of this page, look at the length compared to all other yams springs.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
That's a pretty common SW spring to upgrade over the stock spring.
Don't worry about the length of the spring.
Haven't you ever heard the expression...."It ain't very big around but it sure is short".
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah stock spring has been thought to be too long and could coil bind and several broke.....
I would highly recommend adding 2 glide washers in that primary.
Dan
Dan
The black/blue spring is a good one Used by many on here
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I like the Dalton RED, abit less rpms on top.
I tried the black/red and liked it allot when I was running lighter weights (76.8g)HH. Once I bumped the weight up over 79g it just didn't seem like enough spring in there. I had the cat white in the secondary at the time and I couldn't believe how much more backshift I got with a much higher rate spring up front.I like the Dalton RED, abit less rpms on top.
race24x
Where can I get glide washers? Next thing on the list I wanted to turn the bolts around for the rollers and weights. Stock they are wrong according to another post by Thunder Products plus put some locktite on them. When loosening the roller bolts in the primary they all 3 seem to be bent a little. I will be checking them on a straight edge but now I am wondering of I should just replace the bolts and nuts to be safe
Thunder products has glide washers. I can't seem to find a source for better pivot pins and I noticed one of mine was bent too. I totally forgot to measure them so I could hunt for a suitable replacement and the sled is hrs away. If you could measure one of them and post that would be great.Where can I get glide washers? Next thing on the list I wanted to turn the bolts around for the rollers and weights. Stock they are wrong according to another post by Thunder Products plus put some locktite on them. When loosening the roller bolts in the primary they all 3 seem to be bent a little. I will be checking them on a straight edge but now I am wondering of I should just replace the bolts and nuts to be safe
