04mx
- Oct 20, 2015
- canada
- Yamaha
Can anyone clarify something about the ripsaw track ? my friend was looking at the ripsaw tracks and noticed that the 1” ripsaw is rated to have more (ON TRAIL TRACTION) then the 1.250 does this seem right ?
thanks
thanks
Muskrat62
- Dec 19, 2016
- Cannon Falls, MN.
- 2020 SRX, 2018 MXZX, 2016 Blizzard, 2003 RX1 Turbo
I wouldn’t think so and after 600 miles on my SRX with a 1 inch track and NO traction I would say the 1 inch has NO traction... even with 192 studs. Might be my stock clutching too, she seems to back shift wayyyy too early. All I can say is I wish I had a 1.25.
MM
MM
Gotrek
- Dec 28, 2019
- Winterpeg
- 2008 vector rs l-tx
I'm guessing On a hardpacked trail the less lug you have the more traction you will have. The more contact area you have the more friction, the more traction you get. On somewhat loose material then more lug gives you more traction as it digs in and gets the snow under you to compress flatening it out.
Fast
- Sep 25, 2018
No ,the ripsaw 1.25 is ok, the cobra 1.352 is better and the storm 150 is the best on the trails.Can anyone clarify something about the ripsaw track ? my friend was looking at the ripsaw tracks and noticed that the 1” ripsaw is rated to have more (ON TRAIL TRACTION) then the 1.250 does this seem right ?
thanks
possessed
- Apr 18, 2003
- Sidney ME
- 2017 Sidewinder LE RTX 129 Curve Skis 1.0 track header tune 280 hp
08 Apex LTX Yamachager
1998 SRX Bender 835
03RX1/ 1993 Thunder Cat
- YAHOO
- rx11000@yahoo.com
possessed
- Apr 18, 2003
- Sidney ME
1998 SRX Bender 835
- YAHOO
- rx11000@yahoo.com
I didn't like the 1.50 storm track could never get it to hook up but only in new fluffy snow then it was a great track but on hard groomed trail its not that good the lugs lay over and spin spin spin !! just my two cents and if you like Top End you will loose with the higher lugs!!
I'd agree with this, but it would have to be hard pack snow for sure.I'm guessing On a hardpacked trail the less lug you have the more traction you will have. The more contact area you have the more friction, the more traction you get. On somewhat loose material then more lug gives you more traction as it digs in and gets the snow under you to compress flatening it out.
Fast
- Sep 25, 2018
Maybe the 192 IGRIPS i put in help on the hard pack seems to hook good for me but when looking at the track last week i noticed a couple lugs ripped off, will inspect further this weekI didn't like the 1.50 storm track could never get it to hook up but only in new fluffy snow then it was a great track but on hard groomed trail its not that good the lugs lay over and spin spin spin !! just my two cents and if you like Top End you will loose with the higher lugs!!
