newfie1988
- Sep 11, 2008
- St. John's, Newfoundland Canada
Awesome man!, going to be ordering it all over the weekend, you have been a huge help! GREATLY APPRECIATED!....just one more small question then ill stop annoying you, the only cable exstenstion that I need is the Mtn Throttle cable, all other cables should be fine?
Thanks again man!
Cheers, From Newfoundland, Canada
Thanks again man!
LJ 452
With the setup I have I only needed the throttle cable from the Mtn. The previous years I had the Mtn. riser and when I bought it I got both cables and the brake line. Never needed the brake line, the parking brake I put on but it wasn't needed. With pivoting forward you gain some length, so I would say that you could possible go 1 more inch before I would be concerned about the other cable/line. If you feel you need a longer brake line let me know, mines still in the package.
