kampkoleviper
- Feb 17, 2009
- Pennsylvania
- 2006 Apex GT
Got a riser they said it was from an 06 attak for my 06 GT but the micro fiche says they use the same bolts, it's a stock from a Yamaha sled. need to know what it came from so I can order new bolts the riser is about 7" and the bolts measure 8 1/2" to the flange does anyone know which riser I have. Thanks for any info.
rindtj
My guess would be a Mountain riser. I would check that.
It is confusing because Yamaha changed the riser/handlebar combination so 06 is different than 07. But it sounds like you have a mountain riser..
sherlock29
i believe 06 had a 4"or 5" riser... both my apex have 6"...
O7 attak is only a 6 inch riser. I would say it is a mountain also, but I don't know what year. Maybe post the question over in the mountain section.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
give me the stock bolt number and i can tell you how long it is then tell me how long you need and i will give the part# but measure mm
Snowmobileaddict
7" Mountain Riser Bolts Qty4 8FS-23876-00-00 $5.52 each
kampkoleviper
- Feb 17, 2009
- Pennsylvania
- 2006 Apex GT
Ok thanks guys next Q will my stock cables work if I reroute them so the tors doesn't kick in?
sherlock29
yep.... i have the stock 6" riser plus 2" ROX riser.. fits no prob...
