Blue shadow
What about the two other hoses the one from the valve cover going to the air intake and the one under the plenum going to the motor
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Yes look above in the master fix it section home page.
Blue shadow
Cant find anything about what they are doing with the other hose under the plenum going to the motorYes look above in the master fix it section home page.
Turboflash
- Mar 18, 2019
- Southern MN
Did you clean your intercooler? And foam air cleaner element? Is engine oil level over full? That could cause lots of oil vapor into air box.
Blue shadow
oil level is ok ,Did not check the intercooler ,but I will .did another Leak down test on the intake side with the hose block off under the plenum .Is it ok to block off the other end going to the block or does it have to be open ?Running 300 hp tune .
- 157K
