DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My son put an Excell header and exhaust with a fuel controller on his nytro. What rpms should we be targeting? Right now it's 87-8800.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
I think 8900 is the peak rpm. Im sure others will chime in. Did you add intake?
DMCTurbo
- Nov 12, 2005
We have the schmidt bros intake but haven't installed it yet
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
If you decide to install intake you will have to add weight in the primary or you will over rev at WOT
DMCTurbo
- Nov 12, 2005
It makes that much difference?If you decide to install intake you will have to add weight in the primary or you will over rev at WOT
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
i have the same from dave at huricane performance. It adds 18 hp with exhaust, pc5, and intake. I had change clutching to optimize the new power. I did a full clutch kit. Just saying. Pulls to 8900 now. Good luck.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
When you changed clutching I assume you used Dave's helix, weights, arms and primary spring? If so, were his weights he installed on his arms the perfect set up...or did u still have to add or take off any weights?
Also..was your clutching all stock before you added his clitch kit?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Yes it was a complete clutch kit from Dave. Rpms were spot on. Yes it was stock before. He also added overdrive.
