I need to get a wiring harness or the connectors for the wiring under the seat.
I put on a Apex Mountain seat and don't want to pull my wiring out of the rage seat. I would like to sell the seat, I know if I bought it I would like to have the wiring too. The Apex Mnt seat doesn't have the wiring in the seat its between the seat and tunnel.
So if anybody has the part #'s that would help as I can't seem to locate them and the local dealer can't either.
Thanks , Brett
Thanks , Brett
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
I dont think the connectors are available from the dealer. You would be better off just using some commonly available electrical connectors. You could make an adaptor to connect to the factory wires and the same on the other end.
The only other solution would be to locate a old junk seat from a RX1 and remove the wires from that.
