Yamaluff 88
- Mar 27, 2011
- Southern Ontario
- 2016 viper mpi turbo
2007 Phazer
Sled won’t start either. Are these two problems connected? My apex (fuel injected as opposed to the vector that is carbureted) would light up as soon as key turned one position. Checked all fuses and they’re good. Thanks in advance.
theCATman
Carbed sleds don't light the gauge until engine starts.
Sent from my SM-G930R4 using Tapatalk
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Did you check the battery?
Yamaluff 88
- Mar 27, 2011
- Southern Ontario
2007 Phazer
I was boosting off my viper....Turned over fine. I guess it’s a fuel problem. I was just getting them out of storage. It’s going to the dealer for a servicing so they’ll get it looked after.
Yamaluff 88
- Mar 27, 2011
- Southern Ontario
2007 Phazer
Thnx, was hoping that wes the case.
radianguy
- Jan 1, 2007
Is this a new sled to You?
theCATman
You're call on the service, but the carbed 973 is known to be a bitch after sitting weeks or months. Nothing a stealer has to diagnose for you.
Pull the airbox lid & give it a few shots of carb cleaner into the carbs, it'll fire up.
And put a new battery in it.
radianguy
- Jan 1, 2007
That was gonna be my next suggestion, spot on!You're call on the service, but the carbed 973 is known to be a bitch after sitting weeks or months. Nothing a stealer has to diagnose for you.
Yamaluff 88
- Mar 27, 2011
- Southern Ontario
2007 Phazer
We had it last year. It’s my kids sled.
Yamaluff 88
- Mar 27, 2011
- Southern Ontario
2007 Phazer
Thnx for the tip.
Fresh gas in the tank and then pressurize the tank. This will force gas into the pumps and carbs that have drained over the summer.
Komo
- Jul 17, 2016
- New London Wi
- 2011 Yamaha Venture
Out courtesy what happens to the gas in carbs and pump?
evaporates over the off season. the 3 cyl are more prone to it than the 4 cyl but both do it. that is why we run ours every month in off season to prevent this.
