RS Venture 2006 tuning
Pin
Queensville, Ontario
I'm new to RS Venture and snowmobile in general. According to user's manual, I noticed the drive bell is seated bellow the recommanded position on the secondary sheave. It was a new machine, bought last year. Now it has only about 300KM on it. The drive bell is not worn at all.
Should I leave it as is? Would there be any ill effect?
Is there any adjustment I can made to so that it can steer better? The inside ski tends to lift up a little when turning. Would adjusting the front spring tension make any difference? It's set at the softest position. I weight only 135 lb.
Thanks for any suggestions.
