YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
2007 RS Venture ride and I turned off my sled to take a picture then went to turn the key and all I heard was a faint click. I checked the various fuses, I then took off the Air Box and check the fuse by the Starter Relay. Sure enough that single 30 Amp fuse actually was corroded off at the bottom. I then took off the white 3 wire connector going into that starter relay and sure enough that was green with corrosion, I carefully cleaned all of the corrosion in the relay on the prongs, and then put the plug back in along with the good spare fuse--and I at least got that click sound again but that was it. I then put a little grease from the ski spindle in the white connector and try it again. Now when I turned the key it clicks every time I turn it and you can hear a low dull hummm. (maybe a fuel or oil pump??) But still no power to the key. I then tried to jump the starter relay by pulling back the rubber boot on each lead into the relay and tried jumping across the Pos and Neg with a screwdriver and there were some sparks but still nothing turned over. Had to tow it to a road, and pick it up with a trailer. I ordered a new Starter Relay and Wire harness today. Any other places to look?
battery fully charged and tested good?
YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
Yes, in fact took out the battery to check connections and actually used it to start my old Polaris snowmobilebattery fully charged and tested good?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Do you mean the two large leads on the starter relay? If that's the case, then either you have a bad main ground wire connection or likely a bad starter.
x2 on the bad starter.
- 7K
