Sled_NeckX99
- Aug 17, 2018
- Minnesota
- Yamaha RX-1 mountain
So I went to start my RX-1 today and all I hear is a click. Upon further investigation when I jump the 2 relay terminals I get a big spark, and the starter makes this wierd groaning noise like its trying to crank the engine, but it doesn't crank. I can spin the engine over by hand Forward but not backward. Yes my fuses are good and my battery is good. Any suggestions would be greatly appreciated. Thank You.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
Take the plugs out and see if it turns over first . Does the key engage the solenoid (relay)? Basically are you getting voltage to the starter solenoid (relay) when you turn the key? I assume you are if you hear a click. See if the relay is sending voltage and amperage to the starter. Could still be a ground issue or a starter issue. Check and clean all the grounds too if needed. Sounds like a starter issue but I would try the above steps first. When is the last time the starter worked correctly?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Charge your battery.
Sled_NeckX99
- Aug 17, 2018
- Minnesota
the last time it worked correctly was yesterday. yes I am getting power everywhere that you said.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
pull the plugs and try it , make sure it's not hydro locked.
Sled_NeckX99
- Aug 17, 2018
- Minnesota
tried that with no luck, any other
suggestions?
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
Hard to tell , if it worked yesterday and now it won't. As long as the engine is free, then it would have to be battery, wiring, or starter. If you are getting correct voltage and amperage at the starter then that only leaves the starter.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
Use the search , there are some posts about starters melting down internal because it stays engaged.
https://ty4stroke.com/threads/starter.125807/
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
I once had the just click noise after a long ride, but got a boost and it freed it up and never did it again, maybe a different problem though
