Chris Hammer
- Dec 26, 2020
- Sydenham
- Rx Warrior 1000 cc LE 2004
Just got a 04 1000 Rx warrior, and have replaced the headlight fuse 2 times since I got it. Headlights are in good shape but can't seem to figure out why it's doing this?
Is there a short in the hood harness? have you tried just one bulb at a time?
Chris Hammer
- Dec 26, 2020
- Sydenham
I have not gotten that far yet! Good idea with the 1 bulb at a time. Will follow wires backwards.
yammiefan04
- Aug 31, 2020
- Fergus falls MN
- 04 RX warrior, 2008 apex mtx, 2000 sx700r
Check your relays, as when i would go from dims to bright's it would blow a fuse and it happened to be a bad relay. They are on the right hand side just above the foot well.Just got a 04 1000 Rx warrior, and have replaced the headlight fuse 2 times since I got it. Headlights are in good shape but can't seem to figure out why it's doing this?
Chris Hammer
- Dec 26, 2020
- Sydenham
It was in the foam part up in the handlebars, mouse nest!! Chewed the wires causing them to short out.Is there a short in the hood harness? have you tried just one bulb at a time?
