RX Warrior check engine + Warning light still on
Chris Hammer
Age
44
Sydenham
Canada
Rx Warrior 1000 cc LE 2004
G'day, everyone. I got my hand warmers going finally on the sled. Not working the best, got pretty hot at times along with the thumb warmers. Replaced the Voltage Regulator but that did not help. Warmers are having a mind of their own, not being able to stay at one temp.
The Tach meter is bouncing all over the place and I can't set the idle properly.
I know the speedo and gas gauge are not working 100%.
I am thinking the stator is no good? Book says to check 3 white wires with stator coil resistance 0.19-0.24 at 20 deg C or 68F.
I have not gotten to the wire yet, I have to find it. I assume the stator is on the right side and the wire coming out of the engine housing is on the bottom going to the main harness?
Any tips would be appreciated. Thanks
