stephenk
Does anyone know what the optimum engine temperature range is on a rx1. I just installed a temperature gauge and am wondering what it should be. I contacted 2 Yamaha dealers/service shops and they said between 95-140 degrees Celsius (204-284 farenheight), which seems awfully hot. So just wondering what everyone on here is running around ?
thobkirk
I had a temp gauge on mine. It ran between 190 and 195 when it was warm but I'm not sure how accurate it was.
stephenk
190-195. That sounds alot closer to what I would think. Thanks alot
Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
stephenk
OK that sounds close to what I was thinking around the 180 area. No idea what the shops around here are thinking thanks alot for the input
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I have a rear cooler on mine and my temp is 157 down the trail. It is 151 in the powder.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
stephenk said:Does anyone know what the optimum engine temperature range is on a rx1. I just installed a temperature gauge and am wondering what it should be. I contacted 2 Yamaha dealers/service shops and they said between 95-140 degrees Celsius (204-284 farenheight), which seems awfully hot. So just wondering what everyone on here is running around ?
My Turbo Apex runs 168 F.
Fire your RX 1 up now and watch the Temp Guage.
It should go up and then stop & go back down a couple of degrees when the thermostat opens . That is where Yamaha thinks it should run assuming the thermostat is running correctly.
For us Canuks I would think you are looking for 75 to 85 Celsius as an operating range.
PS: I'd consider another Dealer. Yours appears to be not so bright.
stephenk
OK I will try that and see were it sits. I was thinking the same thing when the dealer told me that I even second questioned to make sure we were on the same page. Thanks alot for everyone input!
