tomhardin
- Jan 21, 2009
Where are the zerk fittings on the RX1 suspension? I only find one on each ski spindle.
Tom H.
Tom H.
apltx08
What year or type of SUSPENSION?
on the front, that is pretty much it.
on the rear skid if it is a proaction it should have at least 7-8 grease fittings.
tomhardin
- Jan 21, 2009
'05 RX1. Totally stock, including the suspension. Guess I don't know enough about the possibilities to say more than this. Sorry.apltx08 said:What year or type of SUSPENSION?
tomhardin
- Jan 21, 2009
maim said:on the front, that is pretty much it.
Thanks. It's a stock '05 RX1, whatever suspension that would mean. Guess I don't know enough about the possibilities to say more than this. Going over the suspension with a light, I don't find any zerk fittings where they were located on my old '97 SX 700. So, I'm assuming that means Yamaha has replaced the old greaseable bearings with "lifetime" bearings? Otherwise, I'm just missing finding the zerk fittings.
yamahamaniac
It's in the manual, if you don't have one I don't know if you could find one online?
tomhardin
- Jan 21, 2009
yamahamaniac said:It's in the manual, if you don't have one I don't know if you could find one online?
Thanks for the reply. I downloaded the RX manual earlier, but I still don't find any zerk fittings where the manual indicates stuff should be lubed. Either I'm blind or the manual must be referring to using a spray-on, water dispersing lube????
Tom
Bullet69
There arn't any on the skid of an 05 RX-1 They are a sealed unit that are supposed to be serviced when you change the hifax.
yamahamaniac
That makes sense why he couldn't find them then.
tomhardin
- Jan 21, 2009
Bullet69 said:There arn't any on the skid of an 05 RX-1 They are a sealed unit that are supposed to be serviced when you change the hifax.
Thanks for the info. Guess Yamaha set the the hi-fax replacement routine up to benefit the dealer. When I've read how to replace the hi-fax, I don't remember anything about servicing sealed bearings. Does this mean that the skid has to be essentially taken off and then taken apart?
Bullet69
Yes it does if your going to service those bearings. Yamaha figures that you are going to take the skid out to replace the hifax since the windows on the track are small and the majority of the people are going to take it to the shop to have it done. A Yamaha Tech that I talked to when I was concidering havine grease zerks installed said that in the skids that he had seen, there was less moisture damage in those skids than ones with grease zerks. I suppose being that not everyone greases the skid after a ride.
grumpysanta
early production had no zirks but i have a later 05 and it has all the zerks , and as far as the slides go i cut open two holes in the track to pass the slides thru , 17000 km and its fine
tomhardin
- Jan 21, 2009
Bullet69 said:Yes it does if your going to service those bearings. Yamaha figures that you are going to take the skid out to replace the hifax since the windows on the track are small and the majority of the people are going to take it to the shop to have it done. A Yamaha Tech that I talked to when I was concidering havine grease zerks installed said that in the skids that he had seen, there was less moisture damage in those skids than ones with grease zerks. I suppose being that not everyone greases the skid after a ride.
Many thanks for your comments. Guess it's time for me to call my friendly dealer and see what the freight is on upgrading to zerks as opposed to just lubbing the bearings (or replacing them, whatever) and whether he even recommends a replacement.
tomhardin
- Jan 21, 2009
grumpysanta said:early production had no zirks but i have a later 05 and it has all the zerks , and as far as the slides go i cut open two holes in the track to pass the slides thru , 17000 km and its fine
Good idea, but I'm always a little hesitant to mess around with the track other than studs. Can't argue with 17K km though.
grumpysanta
zerks
you have to shave so little, i used a dremmel and just widened it slowly.
