Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Just got done putting a track in a 23 srx, ripped it around the yard a few times and parked it. I didn’t notice the Sd-19 when it was running but I turned the key back on and the code was on the dash. Can anyone tell me where it’s located and any problems to look for. Not much on this topic, just my luck. Thanks
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Where is it located on the sled?
Doc Harley
- Oct 17, 2016
- Here & there
The wastegate is located under the turbo housing.Where is it located on the sled?
Important: I'm not sure if they just want you to open manually or another way. Please be patient for the more experienced members to reply.
Fords4life
- Dec 7, 2021
- South Dakota
In the nose of sled by other selinoids, water vapor in line will sometimes cause this isue, pull lines let things thaw and dry out.
Fords4life
- Dec 7, 2021
- South Dakota
Wiring harness by selonoid will have a tag stating its waste gate.In the nose of sled by other selinoids, water vapor in line will sometimes cause this isue, pull lines let things thaw and dry out.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Thanks for the reply’s boys. Just took a look at the sled and the solenoid was unplugged, wtf. Went though and made sure all plugs were tight and dielectric grease them while apart. Funny thing is last night riding around the yard I was not impressed with the power steering at all. Took it around today and now I’m very impressed. I’m guessing the alarm Sd-19 killed the power steering. Wonder if any alarm would cut power to it?
Fords4life
- Dec 7, 2021
- South Dakota
Hope you enjoy your new hot rod, beutifull sleds the 2023 srx...home run!!Thanks for the reply’s boys. Just took a look at the sled and the solenoid was unplugged, wtf. Went though and made sure all plugs were tight and dielectric grease them while apart. Funny thing is last night riding around the yard I was not impressed with the power steering at all. Took it around today and now I’m very impressed. I’m guessing the alarm Sd-19 killed the power steering. Wonder if any alarm would cut power to it?
Doc Harley
- Oct 17, 2016
- Here & there
Congratulations....I'm happy to hear this was an easy one.
