APEXMTSEO7
Can anyone comment on results using Seafoam for fuel stabilizer for sumner storage?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Ive used Seafoam as stabilizer for the last 10yrs. But that doesn't make it right.
Motorcycle, cars, snowmobiles, etc.
rbell14
I too have used for many years, never had any issues in anything I stored with it. Works great!
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I use seafoam for a lot of things, but Startron is what I have found to be the best stabilizer so far. My local boat place that store hundreds of boats swears by it.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Seafood is a cleaner & stabilizer. Used it for years with no problems in 2 & 4 strokes and vehicles as well.
Snowman11
Ive used It for years as more of a cleaner than stabilizer , but I've used as such with great results .. I never leave alot of fuel in the sled anyway .. maybe a gallon and I over concentrate (recommend dose) by about 3x with sea foam .. and I run that on start up before I put more fresh gas threw it , seafoam is hands down best gas additive around , many people I know use it all with same results
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
CaptCaper
- Jan 1, 2007
- Northern N.H.
I siphon out the reg gas and put in about 3 or 4 gals of 91 non ethonol gas.. run it for a while.. no worries this way. The fuel is good for at least a few years.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have used sea foam for years with Ethanol and non ethanol fuels and it has always resulted in a motor that starts the next season and runs great.
Sleds, cars, trucks boats, weed whackers, Stihl chain saws, blowers etc. all work great year after year. One time chain saw was two years never missed a beat.
always fill my tanks on the sleds with fresh 91 and put seafoam in them all. i run mine every month up to temp and spin the tracks and have had no issues with any of them. even did a carb clean one year for no reason as they came off really clean storing them this way.
Snowman11
X2 ... Always fired them up and bring up to temp every month or so in the off season to burn out any moisture, also keeps any seals wet and keeps fluid circulatedalways fill my tanks on the sleds with fresh 91 and put seafoam in them all. i run mine every month up to temp and spin the tracks and have had no issues with any of them. even did a carb clean one year for no reason as they came off really clean storing them this way.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I put nothing in my gas for storage but I do fire them up every 1-2 months and let them run till fully up to temp all heat exchangers hot to the touch. never had a problem yet. the bikes I put jut plain Stabil in them as I don't like to start them in sub-freezing temps never a problem with them either. any thing with fuel injection I cycle the fuel pump a few times with the key to ensure the gas going through the injectors is the best available in the system before starting after sitting.
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
Use it for everything. Never had a problem on 30+ years of storing stuff.
coolio
- Feb 23, 2007
I use seafoam along with non-ethanol gas in my sleds over the summer and I've never had any probs. I swear by it and use it on everything. I personally had had Startron fail in my pressure washer and have had marine grade Stabil fail in my generator.
