brad
2004 rx warrior secondary clutch threw two of the ramps out. When it did this , some of the casting behind one of the ramps broke away too. long story short it was way cheaper to buy a new used secondary, than to fix mine and buy three new ramps at $16.00 each. Now my question is... my old one has a gray mark on the spring ,and the new one has a pink mark on the spring. Do I need to swap the springs out? what is the difference if any? The new clutch is supposed to be off the same machine. :
darv
- Aug 9, 2005
- 08 Apex 40th LTX
I think the color is silver not gray and the other is pink the pink is a stronger spring you can use either one.
brad
what affect does the stiffer pink spring have?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Stiffer spring will up shift slower and may not shift all the way out holding the primary back.
brad
Anyone know what the torc is for the secondary bolt?
