jr13322
Just wondering how you change these, I have a broken one, is it still rideable with 2 good ones. I am referring to part: Shoe, Ramp
8ER-17688-00-00
Any help could be great.
8ER-17688-00-00
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I had changed them on my 04 Warrior. Sold that, I now have a 2011 Apex. If I remember they pop in! Wet the end and it will go in with a little tap from a hammer.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Take the clutch apart and they just pop out. I would not ride with a broken one and I would change all 3 at the same time.
jr13322
Great thanks guys, I pulled the clutch cover and spring, I can get at them they just seem stuck in place
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
Just use pliers to pull them off and a rubber malet to set them in place.make sure you use the oem ones, others do not last as long
vx700xtc
X2 on OEM, and replace the bi-metal bushings while you are in there.
Glacierrr
- Feb 19, 2013
Once you have it apart there is a small hole from behind that you can use to punch them out if stuck!
yacob
- Feb 19, 2008
- canada quebec
- yamaha apex se 2011
eom is better
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
X2...oem onlyyacob said:eom is better
