kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Can someone help with the proper washer placement on 09 Apex gt? Between the secondary and bearing there are 2 washers , one is flat and the other is not. Which way does the non flat washer go on the shaft?
Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
the washer that looks like it is milled out a little go's on first, withe the milled out side toward bearing, (it will fit over the collar ), next is the 1.6 thick washer, next secondary, then the two washers that are .5 thick
kered
- Mar 22, 2014
- 09 Apex GT
Are there 2 washers .5 washers that go on the outside ? I have one .5 washer and thicker one that goes on the bolt?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Washers can be various sizes and quantities to adjust the clutch offset (the amount that the secondary is offset from the primary). There are specs for that in the manual.
kered
- Mar 22, 2014
- 09 Apex GT
which manual?
Lonerider
- Feb 26, 2010
- south west mi
a new 06 sled would come with two .5 shim washers and the thicker washer on the outside. If you are missing one of the .5 shims on the outside, your clutch will be OK, ( NOT PERFECT ) The secondary clutch has a little movement in & out. this is normal. As YammyRX1 said, lots of adjusting can be done with a clutch alliment tool to get it Perfect.
kered
- Mar 22, 2014
- 09 Apex GT
Mine is an 09. Do you know what it might have come with? The microfiche shows 2 shims one .5 and the other 1.0 . If the 06 came with two .5 shims maybe they just changed it to one 1.0 shim?
kered
- Mar 22, 2014
- 09 Apex GT
Any idea what the torque spec is for the secondary bolt?
Lonerider
- Feb 26, 2010
- south west mi
46 ft lbs torque on the secondary bolt, and not positive on your 09 apex gt shims.
