SidewinderConvert
4-Stroke Rookie
I am currently aligning the clutches on my new to me sidewinder. When I got it the offset was 61.5mm, the service manual is saying 58.1-61.1mm, by removing the only washer behind the secondary (right against the bearing/clip) the offset becomes 59.6mm.
Is it acceptable to run the clutch directly up against the ring clip on the bearing?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
First off, its fine to let the clutch go against the clip, I even remove the clip if need be, the bearing is not going to come off the shaft and the shaft will not move. The clip is 1.5mm as I recall, its been a while so check that, if you need to take it off, and don't worry about it, nothing bad is going to happen.
59.6mm is still not the correct offset, its still too high.
Check the PTO shaft and bearing to see if the shaft or bearing has moved in, many move in and need to be fixed and loctited so it does not move again. There are plenty of post on how to check the stub shaft on the engine and correct it, just be sure to loctite the bearing in the housing to prevent it again.
SidewinderConvert
4-Stroke Rookie
I checked behind the clutch and it seems to have not moved the stub shaft (there is ~3-4mm between the heads of the bolts and the back of the clutch). I will pull the clutch and check as soon as I get a new puller (I bent mine on a buddies sled) and check.
Reading through various threads the sense I am getting is the offset most people are running is right at or slightly below the Yamaha recommended range. Removing the clip would put me exactly at 58.1mm which is probably where I will set it for this winter.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
58.1 is a perfect place to be..imo
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
The perfect spot is to get a Hurricane clutch alignment tool and you will be bang on my past experience IMO.
thanks Pan
thanks Pan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Arctic cats don’t even have a clip on the jackshaft
ssgzag15
My Brand new,just picked up from the dealer,
2021 LTX-SE, with 0 miles, has exactly 68.2 mm of offset,
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
You better recheck your offset.My Brand new,just picked up from the dealer,
You're probably not measuring it at the correct points on your clutches or your caliper may be a tad off.
If it's that far out of spec your dealers PDI on your brand new sled is FUBAR.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Did you really say 68.2mm or did you mean 58.2mm?
Hard to believe it is 10 mm off.
ssgzag15
With the belt off, From the outside of the secondary fixed sheave, to the edge of the primary fixed sheave, measures 68.2 mm.Did you really say 68.2mm or did you mean 58.2mm?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Did you pull the secondary off and see how much shim is behind it?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Wow really!! How many washers on the back of secondary?With the belt off, From the outside of the secondary fixed sheave, to the edge of the primary fixed sheave, measures 68.2 mm.
I would remove your primary and make sure the pto bearing is properly seated before doing any adjustments!!
68.2mm is way out
ssgzag15
There is 1 shim behind the secondary that measures 1.3 mm
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Take it back to the dealer. Let them fix it.
- 46K
- 31K
