87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Thoughts on wrapping the white (I am using the newer white-white version) secondary spring to 80 degrees vs. 70 degs?
Using Dalton 52-46 helix and need the wrap for backshift and belt grip.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
White spring will coil bind before full shift wrapped that tight, even 3-3 is touch and go.
87gtNOS
- Nov 30, 2005
- Toronto
I have 3mm spacers under the helix...that buys me some space.
So besides the purple EPI spring, where am I getting more side pressure?
Shiek
i thru on thunder products orange secondary spring last weekend wrapped at 3-1 sled pulls to 11,000 now will throw weight at it as i have the quick adjust daltons, before spring i had dalton red wrapped at 6-2 would pull 10,700 , only thing i changed
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Are you slipping the belt in the higher shift ratios? I’d try less helix angle and some more primary weight the bring the RPM back down before I’d go for a stiffer spring. Less helix angle will back shift faster as well.I have 3mm spacers under the helix...that buys me some space.
87gtNOS
- Nov 30, 2005
- Toronto
6-2 white and this helix works perfect....I have the helix shimmed, approx 2.5mm or 3mm. I don't think the white can bind from compression, but maybe from twist?
Just wondering if I need to get away from the WHITE spring, but Trying to avoid using Dalton Red secondary spring...
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
i have the white- white 6-1 and you the bender roller with a 42-37 helix with dragon fly weights sled plus hard too 11200 then drops 10800
Justin W Wiseman
- Feb 7, 2020
- Newfoundland and Labrador
- Rs Vector and Apex RTX
Apex MCX 290
- Newfoundland
What gears are you guys running?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
Stock gears with cobra track loss a little on top end plus hard
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
What’s your issue with the Dalton red?6-2 white and this helix works perfect....I have the helix shimmed, approx 2.5mm or 3mm. I don't think the white can bind from compression, but maybe from twist?
87gtNOS
- Nov 30, 2005
- Toronto
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Ah, gotcha. Remember the part about me mentioning less finish angle on the helix? Lol
I forgot we were talking about a turbo sled here, not terribly surprised that red doesn’t cut the mustard. Dalton has some new beefier secondary springs for turbo applications.
o's srx
I tried the Thunder Products Orange Spring and it works great on both my OEM clutched 2015 Apex XTX, and my fully cluched (Heel Clickers Primary, Advantedge 43-33 helix) '06 Apex with 136 ZX2 rear skid. I've got both wrapped to 3-1 and zero slippage. After a long WOT pull down the lake, both clutches on both sleds are warm to touch, but you can keep your hands on them without them burning which tells me the belt isn't slipping enough to produce the higher heat.
