adeboisbriand
we spoke a few weeks ago. i have an 06 apex gt. i recently got some clutch parts from you and needed some info on the secondary. you answered my intial question on the setting. 6&3 on the setup. My question is with your clutch kit installed will i gain more on top end with a 6&3 setup or a 3&3 setup. Im trying to understand these numbers more. thanks
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
No, you will not rev the proper rpm and lose power by going to the 3&3 setting. Keep it at 6&3 settings for best performance. The lower the numbers the less amount of force keeping the secondary helix from shifting which will lower the RPM and slow the backshift down as well.
