snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Having problems trying to engage reverse after hard running with heavy throttle,and than slowing to a stop,and trying to turn around using reverse,it gives a code SD-26 and will not engage reverse until you shut down motor and restart clears code,than it will go into reverse and back up. Has anyone else had this happen to there winder? And what was required to repair it?
Like when you miss a turn Pete?
Is the pawl engaged with the extension when in forward? Deflection of belt tight?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Under the hood their is two relays in the fuse box. One relay for forward and one for reverse.
I had one go bad and got the same code. But my shift to forward relay was bad and it would stay in reverse.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes steve,like when you miss a turn,not sure about the pawl,but belt is set correct.Like when you miss a turn Pete?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya i might have to check out those relays,it dosent stay in reverse,just dosent want to engage so it can back up,until i shut off the motor.Under the hood their is two relays in the fuse box. One relay for forward and one for reverse.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Your top gear bushing may be going.
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
At the end of last year I noticed that when I engaged reverse that it was louder and engaged hard. I replaced the upper bushing during summer service and now it is quieter and no hard engage. These machines are like high end cars that require more service than everyday vehicles. Annual go through is needed. Gotta pay if we're going to play.
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
What bushing did you end up using for the top gear.....I can't find the 60695K7 McMaster bushing locally..... do you have a part number and manufacturer of what you used.At the end of last year I noticed that when I engaged reverse that it was louder and engaged hard. I replaced the upper bushing during summer service and now it is quieter and no hard engage. These machines are like high end cars that require more service than everyday vehicles. Annual go through is needed. Gotta pay if we're going to play.
Chris Rose
- Jul 29, 2016
- Powassan ONT
I went to Canadian Bearing and purchased #EP161816 p/m sleeve brng. It was installed flush on the outside and the slight overhang isn't a problem but could be made flush. I also had to use emery cloth on a drill bit to open up for proper fit. I'm at just over one thou clearance. I also am using Amsoil chaincase oil.What bushing did you end up using for the top gear.....I can't find the 60695K7 McMaster bushing locally..... do you have a part number and manufacturer of what you used.
Another thing to check is belt tension. I used to think it didn't matter, but turns out I was wrong as a tight belt can cause that code because it won't let the shift happen.
no1b4me
- Dec 31, 2016
Thanks for the details ..... I will call them tomorrowI went to Canadian Bearing and purchased #EP161816 p/m sleeve brng. It was installed flush on the outside and the slight overhang isn't a problem but could be made flush. I also had to use emery cloth on a drill bit to open up for proper fit. I'm at just over one thou clearance. I also am using Amsoil chaincase oil.
Cheers
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Can you show a blown up pic of this bushing you guys are speaking of??I went to Canadian Bearing and purchased #EP161816 p/m sleeve brng. It was installed flush on the outside and the slight overhang isn't a problem but could be made flush. I also had to use emery cloth on a drill bit to open up for proper fit. I'm at just over one thou clearance. I also am using Amsoil chaincase oil.
Pete if you haven’t inspected the top gear bushing Yet just do it. It is the gear that is on the Jackshaft which the main chain is on.Can you show a blown up pic of this bushing you guys are speaking of??
Here
no1b4me
- Dec 31, 2016
I just replaced the top gear with a new gear assembly .... The original one has 2500 kms.... minimal wear just one small area... however I figure this came from poor quality installation at the factory assembly level.... Notice the shaft spline marks on the sleeve bearing coating.... I figure a small burr caused the small area of surface coating wear.
