This one from a 137” with 2500mi on it. QS3’s center shock is just the standard 1.5 like all our Vipers have. Was definitely time.
ewww! not pretty. last time i saw something like that was when i drained an enine with a 20l oil pan and got 20l of oil and 40l of sludge that looked like that in the buckets.
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
totally worth the money vs having the shock blow out....plus throw in a revalve and its a new love for your ride.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Do you think that is from condensation getting drawn in past a seal?
Yes for sure.Do you think that is from condensation getting drawn in past a seal?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Just had mine apart after 4000km and oil was still clean and red but a bit of sludge on the piston from sitting, it separated over the summer.
Yup and if it seperates even more it will start rusting the shims. And piston if steel. Especially the shocks with shaft down. Like fronts.Just had mine apart after 4000km and oil was still clean and red but a bit of sludge on the piston from sitting, it separated over the summer.
hellflyer
- Dec 2, 2008
Wasn't any water in mine just a thimble full of dark Grey debris!
The grey is water.Wasn't any water in mine just a thimble full of dark Grey debris!
Rich Kay
That is not uncommon to see that much.... just water making its way past the ice scraper and bearing seal. Some of it my be condensation from rapid temp changes. It was perfect timing on a service!
Right!That is not uncommon to see that much.... just water making its way past the ice scraper and bearing seal. Some of it my be condensation from rapid temp changes. It was perfect timing on a service!
Rich Kay
People can say what they want about the Fox float type shocks or the Air Wave shocks but I have never seen water in them because of there design...Right!
These are from a shock with way less water in it than the one in first pic. See the black on the set of shims from centershock and also on the piston? That is the first stage of rust. The clean ones are from rear which had no water.
- 7K
