MitchRS
I was out riding during lunch time and went onto an in land lake which had some pretty deep snow. I could feel the belt slipping as I wasn't able to accelerate very quickly, revs went up but I wasn't moving any quicker. Do venture's typically not perform very well in deep snow?
I took a couple pictures of my clutches and shredded belt. I'm trying to figure out what would cause it to slip in deep snow and if the slippage is possibly due to having some snow entering through the top of the shroud where the vent is located?
Maybe someone can spot something i'm not seeing also? The belt is flush with the secondary sheave which I believe is within spec, It's my first time really dealing with CVT's.
Thanks again everyone
its not anything you did wrong. brothers did the same thing. the ventures are clutched for comfort witch causes the belt to slip more and cooks the belt. snow dust might have helped it slipped but the way they are cluched is most likely the issue. we re clutched my brothers and it was much easier on the belt as well as having snappier performance.
talk to the guys at thunder products and they can help you get it straightened out and running better.
MitchRS
Thanks for the tip! I'll definitely look into it.its not anything you did wrong. brothers did the same thing. the ventures are clutched for comfort witch causes the belt to slip more and cooks the belt. snow dust might have helped it slipped but the way they are cluched is most likely the issue. we re clutched my brothers and it was much easier on the belt as well as having snappier performance.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
An old belt will do the same. Mine ended up like yours. I replaced it with a new one and its been going strong for a while now. Every three years I replace my belt now.
MitchRS
It might have been an old belt since I don't know the age of it. I haven't gone back on that lake since I don't have a spare belt anymore but I ordered 2 and will have them by Friday and then I'll see if it still slips in deep snow.An old belt will do the same. Mine ended up like yours. I replaced it with a new one and its been going strong for a while now. Every three years I replace my belt now.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Ya, they do eat belts especially after being on the throttle hard for an extended time in deeper snow. Also, your clutches are badly corroded, and you may want to take some sandpaper and clean the clutch faces, as will help with belt slippage.I was out riding during lunch time and went onto an in land lake which had some pretty deep snow. I could feel the belt slipping as I wasn't able to accelerate very quickly, revs went up but I wasn't moving any quicker. Do venture's typically not perform very well in deep snow?
MitchRS
Thanks for the response. I'll clean the surfaces up today.Ya, they do eat belts especially after being on the throttle hard for an extended time in deeper snow. Also, your clutches are badly corroded, and you may want to take some sandpaper and clean the clutch faces, as will help with belt slippage.
But for the most part, what I'm understanding is that I need to get my self a second sled... a Viper for that matter lol
- 40K
