Windernation
- Sep 24, 2017
- Mn
- 09 Nytro
17 Sidewinder btx se
Just bought a sidewinder btx se and want to up grade the track for the mountains. Sounds like a 2.6 will fit with out changing drivers?? Do I need to change gearing and/or clutch weights to get it to perform well on the mountain? Let me know what you think of have done.
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
I have a Viper MTX Turbo that had a 2.6 powerclaw. I'm not sure if it will fit your sled...
I was told by the previous owner that my sled has xtx gearing. If anything it could have a little taller gearing. Absolutely no issue spinning that track at low speed or low rpm.. Top speed is a little low for my liking. I'd say the MTX gearing was stupid low.. You may need to buy a 7 tooth sprocket if you don't already have it.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
The btx has 8 tooth drivers and will clear a 2.8 just bearly I ran a 2.5 last year with no issues and you will want to change to atleast BTX LE gearing which is 24/50 that will still get 100mph on trails but will perform well in the mountains and drop the tip weight to 3.1 gram rivet and possibly the mid also or your rpms will be low or gear down farther im gonna try 21/50 gearing next year. I ran 8600 rpm with stock weights 24/50 gears and 2.5in track at 10000ft.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
I'm upgrading to a 2.5 track this year on my 18 BTX LE, I wouldn't think I would have to remove weight from the clutch on a sled with 200hp. In saying that I will be at sea level and not 10,000 feet.
Am I thinking right About this ?
Joshua
- Apr 14, 2010
- Newfoundland
I just looked it up and the 2.25" power claw is 47lbs and the 2.5" challenge extreme Is 51lbs.
Windernation
- Sep 24, 2017
- Mn
- 09 Nytro
Where would the best/cheapest place to get the Le gears? And I only need the 2 gears and the chain right? Or could I get closer to mtx gearing without changing to 7t drivers?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Yes at sealevel you will be fineI'm upgrading to a 2.5 track this year on my 18 BTX LE, I wouldn't think I would have to remove weight from the clutch on a sled with 200hp. In saying that I will be at sea level and not 10,000 feet.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
if you want you can run mtx gearing 21/49 with the mtx chain that will get you lower than the btx Le or I am gonna try 21/50 with the mtx chain on my sled this winter at elevation it will be a stretch to get it on but I think the chain will fit.
Mr.Winder
- Sep 25, 2017
- Mantorville
- 2017 Yamaha Sidewinder
Is there a noticeable difference between the 21/49 and the 21/50?if you want you can run mtx gearing 21/49 with the mtx chain that will get you lower than the btx Le or I am gonna try 21/50 with the mtx chain on my sled this winter at elevation it will be a stretch to get it on but I think the chain will fit.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Not much 95 vs 97 mph top end but I already have the 50tooth from my btx Le and have a 21 from asphalt racing so I might as well use them if I canIs there a noticeable difference between the 21/49 and the 21/50?
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Not the best on the phone to see, home computer is best, i got these from my dealer.Just bought a sidewinder btx se and want to up grade the track for the mountains. Sounds like a 2.6 will fit with out changing drivers?? Do I need to change gearing and/or clutch weights to get it to perform well on the mountain? Let me know what you think of have done.
Any chance you could upload it with higher quality? Very hard to read when zooming in.View attachment 131038 View attachment 131039
silverram323
- Mar 24, 2013
- 46K
