Only difference is the SW BTX gets the trail steering post.
SW BTX Bars
Viper BTX Bars
Viper BTX Bars
Yamaporn
- Feb 11, 2009
- Sidewinder L-TX LE
cool video of both:
cool video of both:
I was just going to share that..LOL, thanks. Rick did a killer job on it!!
couch
Curious re the air to air cooler ... looks like its pretty choked off in the video ....... positioning of it might be ok on trails but in powder it looks like its poorly positioned to get air flow ......
I would say so far so good.. we dont have any real production units to verify.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
So why no vertical steering post on side winder btx, is YAMAHA afraid that the glowing header will melt it or what.
Different steering post.. must not fit.
couch
Based on the promo video of the Sidewinder & Viper the air cooler of the sidewinder looks to be completely choked off ... look at the front of the sled ..... the cooler on the phazer was prone to getting blocked off in powder and that well back compared to the sidewinder. Should be a beaut of an engine but the devil is in the details .... air to air cooler will not work if ambient air cannot flow freely across it ....I would say so far so good.. we dont have any real production units to verify.
I get it. But as I said it only speculation that your posting.
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
The Viper turbo models were choking out when going through deep snow.. and look at all the holes and gaps in the plastic on that thing! The placement of the air intake is very questionable for us deep snow guys. I'm sure an extruding air filter will be necessary. I guess we will wait on the aftermarket to figure that one out.
couch
Considering that in powder the air intake vents on the rmk (which are by the steering post) can get blocked off, there's no way that the air cooler on the sidewinder won't. Just as it shows in Yamaha's own promo video (which I do not see as speculation) the snow has the cooler snuffed.... for $20k + Cdn I'ld have expected that somewhere along the way the designer / engineers / prototype / test riders would have noticed esp since the motor is really the main difference between the two models! Should be fine for trail use but for powder riding it will likely need to be repositioned .....
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I wouldn't be too worried, The Phazer radiator got plugged because its HOT and the snow instantly turns to sticky slush when it hits it. I don't really see the intercooler even getting warm enough to "slushify" the snow, the turbo should only be raising ambient around 20-25*f at the boost levels this mill is probably pushing. With that said, even with the intercooler plugged it won't effect power output that much since we are only talking about a 20*f temperature difference which is MAYBE a 2% loss of HP.
